snowmobiler7c
Disassembled 340 motor was seized from sitting before disassembly. What you see is what you get. Block, crank, floating pistons/rods, cam, oil pan, windage tray, all main caps, J heads, valve covers, oil pump/pickup, timing cover, distributer Flex plate. 2 cylinders will need sleeves from pitting. 3rd cylinder has pitting may clean up, but won't know until they start to bore it out. All other cylinders will clean up nicely. Alternator is seized just a core, can is pretty rusty not sure if it can be cleaned up. Casting 11-22-72. I can email.more pics most seem to be too large to upload. $500 must pick up in Newport Mi
