Logan Haun
All,
I have a disassembled 360 magnum that came with a car I purchased over a year ago. I don't know a ton about the engine and I need to get rid of it because I got a different engine. I have the pistons, piston rods, cam, valve train(?), block and heads. The block has had cam bearings installed. I was told that the block was hot tanked. I was told the heads were magnafluxed and had no cracks. The heads do have small surface rust on the mating surfaces. I would like to sell this engine quick because it is just taking up space. The engine is located in Danville Illinois.
