Hi all, I have a used disc brake m/c that I dont need. Needs cleanup. Piston was somewhat stuck in the bore, so I used a large tap on inside part of piston to help remove, that's why there are threads on inside of piston (doesn't affect function).
Spring and plate at very front of bore still need to be removed for cleanup.
$75 US plus ride.
Thanks
Steve
$75 US plus ride.
Thanks
Steve
