Disc Brake Question
68dart-sb
Middletown, Maryland
Will a Control Arm and Knuckle for a 1974 Dodge Dart work on a 1967 Dodge Coronet. I know the Dart is an A body and I know the Coronet is a B body.
The reason I ask the question is because I have a complete disc brake setup for Dart and I have a Coronet with drums and I was hoping to make the change. I think it will change the height of the front end. I do not have a problem with the front being a little lower to the ground.
Thank you for any information.
Sam
Sell the uppers they won't work on a B body.
As greg mentions, the knuckle is a direct bolt on to your existing upper and lower control arm.
