Challenger
i have 69 dart and 73 front disc brakes can the front mount calipers be switch to opposite side for the caliper be mounted to the rear on the front end and if so any problems
From what I understand the main issue (or at least one main issue) is making sure that the soft lines don't crimp bind, move, rub or get in the way of something.
Is there any advantage to be gained by this swap? If not, why do it?
Thanks,
C
