63dartman
I it possible to change the distributor drive gear without tearing everything apart? I've never tried this but seems like you could use a long extended grabber to pull it out through the dist. hole if it's not siezed in there. Am I on crack or not? Mine seems to have alot of play when you grab the rotor and move it back and forth, What is a acceptable amount of play there?
