[WANTED] Distribution block
DVO
Active Member
florida
Rating - 0%
0   0   0
I am in need of an A body distribution block. I took my Dart to the body shop for restoration and when I got it back and started to assemble it the distribution block was missing.:eek:ops: Body guy says he has no idea where it could be so I am screwed until I can find a reasonably price one to install. Please help.:banghead:
Thanks
Dvo
Do you mean the proportioning valve for the brake lines?
Try the Ram Man:
817.691.5996
The Ram Man
7200 Winters St.
Fort Worth, TX 76120
He specializes in Mopar brake systems and may have the one that you need.
http://www.theramman.com/
Do you mean the proportioning valve for the brake lines?]
Depending on the year and brakes it could be just a distribution block. The drum/drum cars had no proportion function within the block. The later disc/drum cars had another valve in the rear circuit that may have provided a proportion function
DVO I have a good distribution block for a drum/drum car if that's what you need. Let me know
I have one for a disk/drum 74. Almost new put it on then went adjustable. 50 SHIPPED?
