I have a metal gasket that came in the engine gasket set. It is the same size as the distributor base. Did the 72 318 use a gasket and o-ring. This one from Victor is v shaped. So if it is used, does it matter if it is V or ^ ? Also what is the 3 1/2 inch felt gasket for?
