There was no '93 LA 360. '92 was the last year for them. If it's a '93 dated block, it's a Magnum.
They all used distributors, albeit locked-out computer-controlled ones. If you're removing the EFI, then throw a LA distributor in there and go.
.............And even Magnums have a distributor, it's just that instead of triggering the spark, they just have a once-per-revolution cam sensor setup inside
