Do i grease the clutch fingers?
Patrick
Olney, MD
Newbie here regarding 4 speeds.... Getting ready to put the 4sp on the motor but not sure if i'm supposed to apply a little grease on the clutch fingers and/or the throwout bearing face. (I did make suer that the bearing is packed with grease).
thanks!
If you want to brush on a chemical like SLICK50 where metal meets metal go for it. Grease wont stay on there. It'll simply create a clump of clutch material adding to the mess in the bell housing.
