Dodge Dakota V6 flywheel on a LA
Mopar General Discussions
  1. 68383GTS
    68383GTS Well-Known Member
    7,401
    883
    Nov 15, 2007
    East Peoria,IL
    Local Time:
    11:41 PM
    Will a 88 Dodge Dakota V6 flywheel work on a LA 318. I want to bolt a 1973 318 up to my Dakota V6 5 speed.
  2. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    17,104
    6062
    May 13, 2010
    Grand Tetons
    Local Time:
    11:41 PM
    Probably not. Balance issues
    • Thanks! Thanks! x 1
    • Professor Fate
      Professor Fate Push the button, Max...
      1,021
      1283
      Jan 13, 2020
      Wisconsin
      Local Time:
      11:41 PM
      3.9 and 318 are both internally balanced. You should be good to go, just make sure the 318 crank is drilled for a pilot bushing/input shaft clearance.
      Edit: As long as you're not using the computer controls on the 318. That flywheel only has 6 pickups for the crank sensor. If you're carbing it, you're good.
      • Jadaharabi
        Jadaharabi FABO Gold Member FABO Gold Member
        7,644
        8350
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        11:41 PM
        I believe the 3.9 flywheel will bolt up just fine to the 318. However if you're going to time the 318 off the flywheel you will have to get a 318 flywheel or 5.2. 6 vs 8 on the timing.
        If you're going to run a distributor with its own advance and not worried about the computer controlling the timing you'll be fine.
        • 68383GTS
          7,401
          883
          Nov 15, 2007
          East Peoria,IL
          Local Time:
          11:41 PM
          Yes going with a carb and getting rid of the computer..
          • Like Like x 1
          • mopar56
            mopar56 Well-Known Member
            684
            108
            Jun 19, 2014
            British Columbia
            Local Time:
            9:41 PM
            Yep, works fine, I needed one for the kids carbed 318 in his 70 duster, went to the pick and pull and grabbed one from a 3.9 dakota, just machined and put it together! Been in there three years now.
          • Jadaharabi
            7,644
            8350
            Jan 8, 2016
            Peoria, Illinois
            Local Time:
            11:41 PM
            Say this again please.
            • Like Like x 1
            • moparmat2000
              17,104
              6062
              May 13, 2010
              Grand Tetons
              Local Time:
              11:41 PM
              Forgot about that neutral balance thing, still thinking 360
            • AJ/FormS
              AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
              19,185
              7086
              Jan 19, 2014
              South-Central Manitoba,Canada, 900ftelevation
              Local Time:
              11:41 PM
              AFAIK, 88s were still carbed?
              Oh wait, I think that was 5.2s were still carbed.
            • 68383GTS
              7,401
              883
              Nov 15, 2007
              East Peoria,IL
              Local Time:
              11:41 PM
              318 with a carb and getting rid of the computer...lol
              • Jadaharabi
                7,644
                8350
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                11:41 PM
                Are you using a V6 to V8 adapter kit or a 5.2 side mount block for this?
              • 70duste
                70duste Well-Known Member
                127
                64
                Aug 25, 2014
                il
                Local Time:
                11:41 PM
                it will work, I did a 340 swap in a 91 Dakota , no problems
                except 1st gear was a waste of time, lol
              • 68383GTS
                7,401
                883
                Nov 15, 2007
                East Peoria,IL
                Local Time:
                11:41 PM
                Do they make an adapter kit ?
              • Jadaharabi
                7,644
                8350
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                11:41 PM
              • 93ragtop
                93ragtop Well-Known Member
                179
                98
                Dec 23, 2015
                Va
                Local Time:
                12:41 AM
                I did this backwards.... I put a 5.2 (318) flywheel on a 3.9 in my 87 dakota so I could use a NV3500 transmission..... On another site, I have seen others do exactly what you are doing, and it worked. But keep in mind the NV2500 trans, is weak.
                A little off base, but with a 87-90 dakota, your biggest problem is going to get the motor to clear the radiator. In short, I believe there are 3 ways.....
                1. As Shelby did with the 89 shelby dakota's, make a special crossmember and move the motor, trans back. Then use pusher electric fans in front of the radiator.
                2. Use a magnum serpentine belt system, along with pusher fans..... This is what I am doing on mine.
                3. Swap out the front end for a 91-96.... Dodge moved the radiator about 4 in forward to provide clearance.
                Below is a picture of a 3.9, and the factory radiator. Figure the V8 will add 4.5 in. to the length of the V6....
              • 93ragtop
                179
                98
                Dec 23, 2015
                Va
                Local Time:
                12:41 AM
                Wanted to add, if you want any info on what I posted above, let me know, and I can send additional pictures, and links to others.
              • 93ragtop
                179
                98
                Dec 23, 2015
                Va
                Local Time:
                12:41 AM
              • Jadaharabi
                7,644
                8350
                Jan 8, 2016
                Peoria, Illinois
                Local Time:
                11:41 PM
                What did you use for motor mounts?
              • 93ragtop
                179
                98
                Dec 23, 2015
                Va
                Local Time:
                12:41 AM
                I am using a magnum motor and it bolts directly to the factory 87 dakota V6 mounts
                • Jadaharabi
                  7,644
                  8350
                  Jan 8, 2016
                  Peoria, Illinois
                  Local Time:
                  11:41 PM
                  I have an adapter.
                  It is a 5.2 magnum motor that I got as a core. If you want it, you can have it.
