Dodge dart radiator swap
swingercanada
Active Member
canada
will a radiator from a 1968 dodge dart 318 auto non ac car
fit a 1973 dodge dart 318 auto non ac car?
thanks
it will bolt in and physically fit, but you will need the cast iron water pump and pulleys from the 68 318 car as well....in 70 and up small block cars came equipped with an aluminum water pump, which is a little longer in length which also uses a different offset pulley configuration.. which also had the outlet on the passenger side...using a different radiator as well..with a passenger side lower outlet, and driver side inlet..
