[WANTED] Dodge truck steering wheel
mopardude318
Gilroy, Ca
I’m looking for a steering wheel for a ’74 Dodge 4x4. I’ve been told 2WD have different splines up top so need a 4x4 wheel. Thanks.
Gilroy ca 95020
I don't agree on different splines between 2wd and 4wd in any Dodge pickup from '72 - '93. Spline wise even passenger car steering wheels of the same years can be used. Do you want something you can use or a '74 specific, restoration correct, steering wheel ? Color preference ?
MF, I just scrapped a 75 PW.
It still ran and drove when I started taking parts off.
4WD trucks and others with a straight front axle use a steering wheel with no master spline. Otherwise, the shaft is the same diameter and if you file the master spline area on the wheel, you can swap wheels.
