The only '67-'76 cars that should have the radiator mounting locations in a different spot are the later cars with 26" radiators, all the 22" radiator A-bodies seem to use the same locations.
If this is the case then when they made my 22 radiator they put flanges on it for a 26" one and are misinformed. Not one hole lined up with my 67. What i ordered was a 22" for a 73-76 A. At this point when it didnt fit and measured the same as theirvengineering drawings, i assumed 73-76 is/was different than 67-72 on the 22" radiator. I modded the mount flanges on the radiator to fit my car, and left the mount holes in the rad support where they were.
Thank you for the compliment on my lower radiator support crossmember. Yes it took an awful lot of time to make, and i have a fair bit of work left on it before i can put it in primer. however as nice as their core support is, i dont have or can justify spending $350. What i do have is a little time here and there between work, and family life.
I also have sheetmetal fab talent, access to a hydraulic shear and an 8' long sheetmetal metal brake, and a 4' long sheetmetal pan brake at work, so for the most part i fab whatever i need if i can. I copied the uscartool torquebox plates front and rear as well.
Basically things that i can make, i do not buy, this saves me cash for the items i cannot make and have to buy. I will be snapping pix of the UScartool rad support and archiving them, as the 69 notch i have for my son is pretty beat up in this area too. I may have to make a new one of these from scratch.
The next and last things i have to fab up are the support bracings at the upper control arm and shock tower area. I already have pix of the uscartool pieces, i just have to template it all out, and make the pieces.
