Dominator throttle bracket?
pettybludart
Ontario,Canada
Today I swapped out my 850dp for a Domiator.I had to buy an adapter for my M1 intake to the dominator.When I went to use my aftermarket throttle bracket...she no workie.WTF?Does anybody have pics or can tell me what they,re using to hold their throttle cable.I did start the car to see how the Dominator worked.The engine sure liked it,mega responce.I,m using a 72 Duster gas peddle and throttle cable on my 66 Dart with 410c.i.
Does Summitt make one that will fit on the 2 carb mounting holes?
jegs makes a copy of csr,s a lot cheaper. uses a lokar cable
I cant wait to hear back on this,please respond back!. I had a 8082 2 circuit,on my 396 square port.Way more driveable than a 850 d/p.
Here's a link to AED, whom I use regularly. They are out of Richmond, VA, and they build some of the best carbs in the industry.
They also have a nice billet bracket to work with 4500's.
http://aedperformance.com/New Components.htm
Southernman
Southernman,I already run an AED850HO and love it.I got the BG Dominator from a member cheap and want to try it.I also just ordered the AED bracket from Summit.I,ve been preaching about the AED carbs for over a year now and Summit now sells them at reasonable prices IMO.:cheers:
Dominator....SWEEEET. I've been thinking about switching to a 1050 dom sometime soon as well. Let us know if you pickup a chunk of ET.
i use a jegs like what daredevil said but you can get one that uses stock mopar cable i use a 6cly. cable its longer than a 8cly. cause of the taller intakes
No part number but it's a CSI
I swapped a950hp two years ago for a 1050, and picked up .3 seconds with no other change. Can't remember the increase in mph, but it was noticeable.
