i need to replace lower bushings in 68 dart is this a big job or can a novice do this i am good at replacing parts as long as there are no issues any tips
Should be pretty easy. If you can have a helper that is the best route. Take the door off or pull the lower hinge out. You can use a jack stand to support the rear of the door. Drive the pin out, replace bushing... done deal.
