Thanks, that clears some things up. May sound silly but where can I order the factory service manual? I'm kinda new at this..... Is the little plastic pinch clip going through the glass at bottom right the only thing holding it in the bottom chanel?Yes yes and yes
You MIGHT be able to disconnect the door glass and lower it into the door cavity, to allow the vent frame to be removed.
I recently replaced my convert glass, I found that removing the door glass was streight forward, the vent came out easy enough, window regulator easy.
Putting everything back easy, getting it adjusted, HARD!
The felts (wiskers) can be removed with glass in, lower the down stop a lot, to gain access.
Get the factory service manual there are procedures there
Download an FSM from mymopar.
Found the FSM and ordered it. Thanks.Download an FSM from mymopar.
I downloaded one and printed out all the sections I needed as I needed them. I have just about the entire thing in a binder now. I’d like to get an original one to throw in the car when I finish it thoughNothing beats having a paper manual
Except a PDF version where you can print out the pages you need and keep your 54 year old original in good shape!Nothing beats having a paper manual
View attachment 1715721327 View attachment 1715721328 Trying to remove door glass and wing window assembly. I have removed the three screws at the front of the wing window. It now appears as if I need to remove the bolt anchoring the forward vertical door glass Channel to the door. I'm assuming the door glass needs to come out in order to finish removing the wing assy. Correct? Also I'm assuming the window felts can't be removed with the glass still in the door. Also, am I going to regret taking this stuff apart?
