door hinge ?
rm69dart
Costa Mesa, Calif.
hi every body
I have a dart Iam putting together, installing new door pins, but the lower hinge had to washers as shims is there any oem type shims or it does take any shims. Thanks
Shims were installed as needed by factory or by service mechanic later on.
The flange on the bronze bushings serve as a thrust washer and shim. Clearance for those will need to be cut in to one of your hindges.
