Tiki bar jim
Active Member
Good afternoon Mopar People, I have a 64 Valiant wagon that I'm having an issue with, it's hard to open when the door is closed tight; I have replaced the door lock mechanism & the door striker latch with NOS parts; the door release button will not open the door. It will work on the first latch but not it is completely closed, have to open it with the inside handle.
Is there any adjustments that I can make to make it open? There is a little play in the hinges not much, door closes tight with no problem. Hinge replacement?
As always thank for your time.
