The steering coupler does not have enough room to rotate. It barely clears the #7 tube. I have thought about shifting the engine a bit but there doesnt appear to be enough clearance on the pass side torsion bar to make a difference.
Has anyone else run into this? Do you have a solution ? I really dont want to ding the tube if I can help it.
BTW , i am using the taller insulators on the engine mounts.
