12many
This would make a great drag car, or cool pro-street ride. Very clean and straight 1995 LeBaron convertible. About 98,000 miles. Runs drives shifts fine. Perfect for a v-8 conversion! Lots of potential and solid base to work with. Solid 100% rust free, ready for your V8 swap, modification. It is currently not charging. Need to replace the ECU as the voltage regulator is integral. Could bypass with an external. Drips oil from the timing cover/balancer or oil pan rail, hard to tell. 3.0 V6, auto, a/c, loaded. Surely someone here with the skills could do the modifications for a small block with this? I've got too many vehicles, this thing is just sitting and no motivation to sort it out. Need it gone asap. As close to $1000 as I can get, make a serious offer and come get it. Can provide as many pictures as you need.
