moparraceman
where are the pit cocks on a 331 1957 hemi so i can drain the block ? or is there any other way? need to het ready for winter thanks
No petcocks unless someone previously installed them; just drain plugs.
You may have to use a small punch and hammer to get through the gunk. Sometimes the build up gets hard like cement.got the pit cocks both lose, open , the drivers side drained for quite a while till water stop, the pass side nothing ? stuck a small screw driver up in ,but didnt help, do you have to drain both sides, or will one side drain the both sides of the motor?
just be careful you don't go through the other side of the water jacket or the petcock itself.You may have to use a small punch and hammer to get through the gunk. Sometimes the build up gets hard like cement.
Man that crank has some really big mains. I bet it'd never break.
It also has 4" pistons on the left bank and 3 " on the right!Man that crank has some really big mains. I bet it'd never break
