Drilling Intake
340 sedan
Active Member
Grand Bay AL.
Is it possible to drill a la intake to fit a magnum engine? i have several intakes and was wondering if it can be done. The 340 is sick and needs attention but I want to go to cruisin the coast and don't have time for the rebuild right now.However I have access to a 318 magnum for the taking will my stuff work on this motor?
Thanks for the help,
:burnout: Jody
Yup. I understand there is a "jig" floating around somewhere
Okay I picked up the 318 last night and will start with the engineering today after work.
I'll let ya'll know how it goes.
Thanks
from what I have heard the jig is not for the intake its for drilling the heads for the LA bolt pattern
Right. For some reason I had "heads" in my head when I wrote that, didn't realize the OP had asked about the intake
A friend drilled his intake for magnum heads. Not sure how but it works just fine.
just looking I think it can be done and not that big of a deal,cut some wedge spacers from aluminum pipe and slot the hell out of the intake.
Thanks for the input from you all.
Jody :glasses7:
That's what I read in a magazine once. "Waller" out the holes and then use a wedge spacer. Don't remember what magazine though, maybe one of the older Mopar ones?
I had an M-1 dual plane for a Magnum, so I didn't have to worry about it.
