mopowers
Anyone got any tricks to drilling and tapping into a MIG weld (using ER70S6 wire)?
Tell us what you're up to. May be we can help.Anyone got any tricks to drilling and tapping into a MIG weld (using ER70S6 wire)?
what kind of metal is the weld on ? and will you be boring through the whole weld or just catching the side like half the hole or less ?
You know why? Because most "crap taps" are made from cast steel, or even sometimes cast iron. That's why they wear out so fast and or break easily.Try the hard stuff but you could always use a thread-sert in a larger hole. Wont hurt to try. Isnt MIG weld very brittle? I can barely tap cast iron with crap taps.
If the part can handle the heat, getting it cherry red and then slow cooling it should soften it and make it drill/tap easier. Quality cobalt drills and a good tap will make a difference too.
Maybe a question for another thread, but.....Is there a "soft" MIG wire or is the hardness a product of the process? TIG welds are workable, why are MIG such a bear?
There is a wire called Easy Grind. I have never used it and yes the process of welding TIG and MIG heat the base metal differently so MIG cools faster hence a harder metal than the TIG that heats the base metal more so it takes longer to cool.If the part can handle the heat, getting it cherry red and then slow cooling it should soften it and make it drill/tap easier. Quality cobalt drills and a good tap will make a difference too.
I remember reading years ago some guidance from the FAA on homebuilt aircraft that post weld normalizing of mig welds (heat with oxy/acetylene until red, let air cool, do not force cool) should be practiced by most any fabricator for tough joints. .
