drive line swap?
dazedand confused
hollister mo.
I've got a 1965 dodge dart 2 door with a slant 6 and a 904 auto tranny.I'm up grading to a mid 70s 904 automatic.I got a drive shaft out of a 67 dodge dart 2 door with slant 6.the yoke slides right in but the shaft is too short!Is there a fatory drive shaft that will bolt right up or if not what are the measurements from eye to eye so I can take the yoke and end piece to the drive the drive-line shop?
You need to put the yoke into the trans, pull it out 1". Measure from the center on the "U" joint on the yoke, to the center "u" joint on the rear axle yoke. that will be the size drive shaft you will need.
