Miranthis
273 4bbl. Just removed the engine and there was no exhaust gasket on the pass. side, but the heat shield gasket was on the driver side. Can I reuse that? I don't see many repro ones, if any (see mention of NOS ones, rarely, when I do a search here). If they don't necessarily even need an ex. gasket, if i reuse the same one it should be good. if i do get a leak i suppose I can use a little sealant on the two sides of the thin metal... What have you guys done?
