416stroker
Drivers side early 67-72 Abody lower control arm with sway bar tab. It's been bead blasted, primed and painted cast gray. Still has outer bushing shell in place and the inner sleeve is on the pivot pin. Ready for poly bushings if you choose to go that route. It has some pitting but it's straight and the torsion bar anchor turns nice and free.
$50 plus shipping in the USA.
