[SOLD] Driver's side upper control arm
circlepilot
El Dorado, Arkansas
Re-conditioned, driver's side upper control arm, (from 65 Barracuda) new bushings and ball joint. Also, two new bushings and a ball joint. The reason I only have one, is after I installed the new bushings, in the passenger's side control arm, I determined that the threads in the ball joint port were worn beyond safe use. So I removed the bushings and threw the control arm in my scrap barrel. I was going to use the OEM control arms, but went "tubular." 45.00 + shipping. It will fit in flat rate box.
