driveshaft length...?
70-duster
yorkville, IL
Is the driveshaft length different whether you use a 904 or 727 transmission? I have a 71 duster that I am putting a 318 in with a 727 transmission. I have a guy that has a driveshaft but it came out of a 904 car.
727 Transmission is longer so the driveshaft is shorter, plus the 727 slip yoke has more splines and is larger. U joint can be large or small. What rear end is in your Duster?
Same question about leanths diffrent situation, I will be swaping a 904 with a 727 and installing an 8 3/4... How much should i shortened or how long should my drive shaft be....
