SlantedDart
Per nhra rules it will be 1/4” thick 2” wide steel and with the slide adjustment you’ll be able to get within 6” of the u-joint.
Gauging interest if I should make a production run of these to sell
It’s pretty universal but based on an A body. What’s your sub frame width on the inside?I'd be interested if you can offer some detail. I need one for a '69 Charger with US Car Tool subframe connectors and a GV overdrive so I think it would need to be wider that an A body to reach the connectors. Can you give me upper hoop section dimensions so I can make sure it fits in the tunnel further back? Can it be made to B body width or is it already pretty universal?
I'll get a measurement for you this weekend.It’s pretty universal but based on an A body. What’s your sub frame width on the inside?
