Dropping the steering column, any tips?
Luftwaffles1000
1975 Duster Slant Six
Alabama
I'm going to be tackling the dash renovation soon. When I drop the steering wheel, what do I need to be mindful of. I read in the service manual or forum (can't recall) about not forcing it as it will mess with the shifter linkage, etc.. Any tips? I'm a newbie.
Thanks :burnout:
If you want to remove it completely, drive the pin out of the steering coupler. I use "selected" open end wrenches to pry between the coupler and box.
What year????
In 67 there are the two nuts and studs under the dash, and a third bolt further down.
If it's a column shift you'll have to deal with linkage.
And the two electrical connectors
What year????
Lawd I keep forgetting to mention it's a 75 duster with a slant 6
