I have for sale a new drum brake residual pressure valve from Master Power Brakes. This valve is used to prevent long pedal travel when applying the brakes on a drum brake application. It acts like a one-way valve (check valve) to maintain brake system pressure and will also eliminate a spongy pedal. This 10 psi version is used for drum brakes and provides just enough residual pressure to firm up the pedal, yet not too much that the brakes drag.
When Do I Need A Residual Pressure Valve ? - Strange Engineering
This valve is a 10 lb. valve and is still in the original packaging. I would like to get $8.00 for it plus the shipping.
Ken
Edison, NJ
Ken
Edison, NJ
