69FBCuda
Stand back 10' for your viewing pleasure & Safety
Dual exhaust system "Yoke" back 1.5" for a 1963 Dodge 440 Wagon B body with small block yokes(3.25 hole CL to CL)
1.5" dual exhaust manifold to tips, mufflers(612212) with H-pipe crossover 3 sections each side, has Cherry Bomb mufflers. You will need to either weld or band clamp(5 total) should be pretty easy to align the cuts so you could do the welding on the ground. I can provide the measurements for point A to point B that you need. Look to be mandrel bent? I received this with other parts purchased and am charging $25.
I think shipping will be around $100 due to the length. I am willing to drive up to 75 miles one way for $100 total which would include the exhaust.
Cherry Bomb 3.5 in CASE X 22 in - 2 in - BLK
Cherry Bomb 612212: 3.5 in CASE X 22 in - 2 in - BLK | JEGS
Info
73" longest section
50# +/-
16" across +/-
Chrome tips, light rust
Plus shipping, Paypal accepted-buyer pays fees if any
Thanks FABO
Info
73" longest section
50# +/-
16" across +/-
Thanks FABO
