You would have to get a well thought-out single plane to be able to pickup all around like he mentioned. A not too big port single plane may help. But usually steeper gears will help makeup for some lack from a single plane. Given you have only 3.55's i wouldn't.
Volume vs. Velocity comes into play dealing with intakes. Single planes, have lots of volume. Not split in the plentum, runners are usually short and fat. Low velocity, high volume. Which means your low end will suffer, where as the top end will scream due to the extra volume in the plentum waiting to be used. You also will likely need to spin a higher rpm to gain the most out of the single plane.
Your downfall i'd say is the 3.55s, given a 4speed. thats good. It'll take longer for the powerband to hit than if you had, say 4.10s.
Dual Planes, have short and long runners. Long runners offer low rpm velocity which will give you your low end torque. Where on the top end the shorter runners will be most efficient. This is what your common street car usually runs like yours.
If i were you, i'd run a Edelbrock Air-Gap intake, with a 650/750 Double-Pumper. If you had a nice set of 4.10s, bigger cam and some ported heads, i'd lean twords the single plane.
Just my 2cents!
