Babyblue66
Cool dude
Is there a source for the bushings inside the distributor? This is a 1970 dual point small block distributor I need to rebuild. Shaft has play at the top because the bushings are worn.
Thanks, but I just realized it's the advance unit that's worn.Halifaxhops /member
He can do it all!Thanks, but I just realized it's the advance unit that's worn.
If it is the same prestolite dist as 66? up, the advance plate rides on a ballbearing between the two plates.Thanks, but I just realized it's the advance unit that's worn
I took apart another distributor and tried that part that has the points lobes. The part that slides over the top of the shaft. It is loose too. The shaft where that slides on is smaller than it should be. Someone "Rebuilt" it. I'm not sure what they did. So basically, I need a whole new distributor shaft.I have it all if needed PM me You sure the advance plate is worn? Be the first one I have seen in 40+ years of doing this. Might just need cleaning and re greasing.
oI have it all if needed PM me You sure the advance plate is worn? Be the first one I have seen in 40+ years of doing this. Might just need cleaning and re greasing.
