Why aren't regular snap rings used in place of spirolox retaining rings?
They can be. They're just a different form of retainer. Early hemis, polys and slant sixes used them. Might be more. I'm unsure the factory ever used Spirolox.Why aren't regular snap rings used in place of spirolox retaining rings?
#not all motorcycle pistonsI thought in some cases they were. Like all motorcycle pistons.
Is because, You haven't seen yet what can go wrong with a common retainer, used in an abusive environment. Spirolox won't break or fall out, a regular offering can cause a worn slot/trough gouge in the cylinder wall when it fails. Correct orientation of the end gap of a common retainer can prove to be verry beneficial. Never put the end gap of a regular clip at or near the 3 'o'clock or 9 o'clock placement. Centripetal force factors come in to play. They will fatigue if so. 340's (high revers) and 390 fords (turds) are usual culprits of this type of failure. Pics include the 1 type that can fail/ break and the type that can fall out, (pic to follow when I find it).Why aren't regular snap rings used in place of spirolox retaining rings?
How can a snap ring "pop out" since it's under pressure?Snap rings pop out I've sleeved many 340 because that cheap snap ring popped out after many miles from the factory also /6
Centripetal force.How can a snap ring "pop out" since it's under pressure?
