Maybe I should clarify......the seat pops right back in on top of the steel.
I had to trim some of the round wire frame for the lower portion of the seat since I mini tubbed the car , but it looks show room.
I am about to put the motor back in , so I can't say if there is a lot of vibration noise from it........but with a motor plate in front , a solid roller 405 " and the minimalist approach to exhaust , it is going to be noisy anyway.
The toughest part of the deal was sealing the package tray area......three speaker holes and a long slot required cardboard templates , cutting the steel to fit and tacking the large pieces in , riveting the cover for the slot and sealing them all.
With the window in , it got tight.
And I am not sure if a track inspector would even look up there , but it wasn't worth gambling that they wouldn't.
