Dumb Question
FASTBACK340
Legandary Member
Legendary Member
In another thread I posted my refinished dash cluster. I had pulled out all the lenses when I painted it, including the HI BEAM & BRAKE indicator lenses. My dumb question? Which side do they go in.... I *think* the HI BEAM lense goes in the lower left, and the emergency brake indicator on the lower right. I already figured out the directionals....;)
abodybill said:
Yep you think correct-HI Beam left/Brakes right.
Thanks Bill ! Now all I have to do is remember where I stashed the `lil buggers....:-k
No problem but watch not only what Tony said but,don't forget the o-ring or they will be loose in there.
I can tell you from experience!
Well, looks like I'm a gonna fabricate a set `cuz I can't find the `lil bastards! Thank goodness I'm proficent with a blade & plastic ;)
