Dump Valve - Torqueflite
dart73br
Member
Brazil
Hello transmission experts,
I´m thinking in installing a dump valve system but I can't use transbrake VB in the class I run. Boosted application so need to increase my launch RPM to create some boost. My torque converter flash stall it´s 3500rpm but I just can footbrake to around 2000rpm. If I could hold the car until flash stall would be great.
1st stage would be converter feed (will tap some connection in the case where fluid goes to converter), 2nd stage is cooler feed. All returning to transmission pan.
Do you guys thinks this should work?
Thanks and Br,
