WAO WAO FABO Gold Member Joined Dec 22, 2007 Messages 29 Reaction score 0 Location Phoenix, AZ Feb 23, 2014 #1 Will 1973-1976 duster door fit a 1971 Demon?
dodge71demon Well-Known Member Joined Apr 29, 2009 Messages 3,433 Reaction score 633 Location Indiana Feb 23, 2014 #2 Yes but there are a few items different on the inside Plastic top caps ( Demon is metal) Door panel window crank and inside door latch location
Cuprum-74 Moparus Fanaticus FABO Gold Member Joined Dec 6, 2012 Messages 723 Reaction score 324 Location Utah Feb 23, 2014 #3 Yes they should fit. you will need to make sure your hinges are not worn to the point that it drags the door on the bottom door sill.
WAO WAO FABO Gold Member Joined Dec 22, 2007 Messages 29 Reaction score 0 Location Phoenix, AZ Feb 23, 2014 #4 Thanks, then will the windows and channels work in the Demon door?
dodge71demon Well-Known Member Joined Apr 29, 2009 Messages 3,433 Reaction score 633 Location Indiana Feb 23, 2014 #5 WAO said: Thanks, then will the windows and channels work in the Demon door? Click to expand... Depends what you mean by that Yes the later door will bolt into the demon glass and everything No the glass is different on the bottom mounting holes so you can not put the later glass in an earlier door and vise versa
HemiSSDart Dartus Interuptus Joined Feb 20, 2013 Messages 3,177 Reaction score 3,142 Location Illinoisy Feb 25, 2014 #6 The doors will bolt in and can be used as is but none of the guts including the window will work in a 71 Demon door shell, that should clarify it. Inside the door will look completely different from the other door though.
