Duster Glass compatibility
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
Hey guy's got a question on some Duster Glass. I have 73 Duster glass. Is it the same / fit in a 70 Duster?
@moparbuff
Inquiring minds want to know !
Thanks in advance.
Door and flip out as well as windshield and rear glass.
I know that 75 door glass is different than 73. 75 has a couple more mounting holes.
Windshield '70-76 Duster, Demon, Sport
Door glass '70-2 Duster and Demon
73-early74 Duster and Sport only
Late'74-76 Duster and Sport
Quarter glass '70-72 Duster and Demon
'73-6 Duster and Sport
Back glass '70-76 Duster, Demon, and Sport
All glass could be clear or tint, and the back glass could also have heat (defroster grid) in the '74-6 years.
Excellent! Exactly what I needed to know.
Thanks to all
The quarter glass can be swapped between early and late, but you need to swap the frames as well.
Ie, you can put 70-72 quarter windows in a 73-76 Duster, but only if you use the 70-72 frame and latch because the hole in the glass for mounting the latch is in a different place.
You would also need to add clearance to the sail panel around the latch mechanism, if you were adding a 73-76 quarter glass and frame to a 70-72 car. Or using an early metal sail panel on a 73-76 Duster or Dart Sport.
