dusted72
Thanks Hemiroid!!!!
Can I get some really good pics of an original Duster Lower drivers quarter. I am trying to make my own patches and the curve just doesn't seem right. My car is a 72 but I don't think it matters. Thanks guys.
Ok I think it close now.
The lower body line is about an inch above the top of the patch but the surface rust makes it blend in, and the bottom is about the same curve as a broom handle then I flattened it out a little. I tried to keep it under the body line so I wouldn't loose it after I weld it in. I plan on flanging the patch under the quarter so my fill goes done instead of up if that makes sense.
