Duster Sport Mirror???
1971B7340
Active Member
How do you tighten up a non remote sport mirror? The mirror is loose in the housing an just flops around but I cannot figure out how the mirror is attached to the housing. Everything else is fine, the mirror just will not sta adjusted. Is the ar mounting screw under the glass when you un-glue the mirror from the housing? Please Help!!!!!!!!!!!!!
Mike
i believe if you take off the mirror, there is a screw on the bottom in the base that you can tighten, not sure but im sure others here will let you know if im right or wrong
One screw in the bottom of the base when up side down only removes the base from the head. I do not see any other screws. The piece the cut piece of mirror sticks to is what is loose, it looks like it is mounted to one pivot shaft inside the mirror head. This is what needs tightened some how.
