There is also some products you can spray on then paint over that is great also.I was watching hot rod TV and they was applying some to a car they were building.The Dynamat is some really good stuff,and when you put the carpet in make sure you use a good jute backing with the carpet and you will be hearing little to no noise!
Bobby Dodson
