E58 Cop/HD.360LA questions ..
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
The windage tray is out of an E58 motor.
Will it fit in a 360 magnum ?
IIRC the 72-73 E58 was also fitted with the 72 73 340 cam ????
If the cam is good maybe someone could spec it out
Windage tray will fit the 5.9 Magnum. Same stroke crank. Sell the 4 main cap bolts with it if you have them. Unless the cam is like brand new, it might not be too hot of a seller. You can buy new ones made to 340 specs, which is what an E58 cam was.
'72-73 E58? Never heard of one, pretty sure the first year for an E58 was '74.
There was a '72-73 E55 though, and it had the 340 cam....because it was a 340. :)
