E85
A carb designed for E85 since you need to run more volume of fuel.
basically u need to set up ur whole fuel system to run alky. when ur dealing with an alcohol fuel it is very corrosive and will dry out anything rubber. so what has to happen is the carb needs to be re-jetted to run the proper stoich, which is 9.7. u need to run Teflon seals and gaskets in the carb. i think efi fuel line that has the liner is ok. the fuel pump has to be set up for alcohol.
this should be it. just make sure u get rid of anything rubber, because it will dry out and crack.
to be honest i can't remember... i think the foam is ok just not the bladder, if made of rubber. i helped in the pits on a friends car that ran straight alcohol and we had to get all the alcohol out of the system and then poured WD-40 and ran it on that for a minute so nothing got messed up but E85 is no where as potent.
probably look it up online or call summit and ask if they carry a cell for alky or not.
