dschem
Hello,
For lack of a better place to put these I will try here. Since you do wear these in the interior.
I have two windbreakers from the early 70's
The blue one has a patch that says Cuda Plymouth and the small label only says M. It has a hood and the following are the measurements: Laying flat 22" across the bottom, 22" across under the arms, 22" bottom to zipper top, 22" underarm to end of sleeve, 32" top of shoulder to end of sleeve.
The red one had a Dodge patch and 2 white stripes on the sleeve. It has a label and I believe it says M. It is lighlty insulated. The measurements for this jacket are: 21" across the bottom, 21" across under the arms, 23" bottom to zipper top, 21"underarm to end of sleeve, 29" neck to end of the top of the sleeve, 3" elastic cuffs.
I will post a few pictures of each. I want $75 each including shipping to the continental US. I am in Waukegan, IL.
