[Found!] Early A (65) 273 V8 2 piece Power Steering Pump Bracket
  • Thread starter Deleted member 38666
  • Start date
D
Guest
Members. I need the 2 piece power steering pump bracket for a 1965 Dodge Dart 273 V8 engine. Let me know if you can help me? Enclosed are some photos of what I need. 65 Dartman responded to this thread with other Mopar vehivle engines that used the same bracket. This widens, as 65 stated, the criteria for the needed bracket (See Don't input in following response). The title of the photos shown, of course, is not what I need. The photos were just in that photo file. Thanks. PM me at Old Dart 66 if you can help me out. Best to you
They used the same brackets as far back as the late 50's on the Dodge/Plymouth big cars with PS and poly 318 and cars such as the mid 60s Belvedere/Coronet with the poly 318 and PS as well mid 60s A bodies with the LA engine and PS. This can widen your search criteria!
Thanks to you 65 Dartman for your input. Old Dart 66
