Early A K-Members?
64 SRT8 Dart
Colorado Springs,Colorado
Hey all! Are all the early A body k-members the same whether it be a /6 or a small block?? 63-66
If so, a k-member from a 64 Dart 170 should fit into a 66 Valiant with 273??
Thanks everyone!
Thanks everyone!
All the same.
so who makes a slant to v8 motor mount kit
Either use a set of OEM V8 brackets with new rubber (or poly) mounts or buy a set of Schmaker's (sp?) conversion mounts. They offer 2 flavors: 273/318 or 340/360 style.
I used a set truck motor mounts and shims , 5/8 on the passenger side and 1/8 on the driver side .
Moparlee that engine pic is sweet .......... I have alot of work to do .
I also have a 340 with a 4 speed and thought that solid mounts would be better so I wouldn't have the rubber blow out and cause damage . 6000 rpm + burnouts at 40' long might do that . I had a pile of mounts and thought I'd use them, and share the info for other people . :))
