View attachment 1715400961 Has anybody tried to use a Mustang two front end on early As. Trying to find a cheaper way to put a G3 in a 65 Cuda. I have a empty block setting in there now but it is bolted up to the transmission.
Man can you turn the spindles around and make them front steer or did you make some brackets and bolt on to those disc brake bolts. I had a 360 in there and was using 340 HP manifolds so not as good as headers but good enough.I just put the early pinto rack through the front of the K member and made my own steering arms out front. 0 bump steer and a ton of room for big headers for my 340.
Well I’m just asking if anybody else has done it I wouldn’t risk ordering all that stuff if I didn’t know if it would fit or not. Hedit has the whole thing for 2K so good price. works on street rods doesn’t mean it will work in my old A bodyI'll be following. The exhaust manifolds/headers might be trying to take up same space as inner fenders. Hope you make it work!
Hemi Denny has you covered.View attachment 1715400961 Has anybody tried to use a Mustang two front end on early As. Trying to find a cheaper way to put a G3 in a 65 Cuda. I have a empty block setting in there now but it is bolted up to the transmission.
Yeah I have already give up on Hedit. Confront control freak doesn’t make it for early either so I’m down to GTS or HDK. I think RMS makes it too. I know it’s hard to do G3’s are cheap. Wish I had those extra inches in the later AsI did it. It's a real PITA. Need custom pan, custom mounts, ... . Can't install motor from underneath, ... . RMS, HDK, Control Freak is the way to go.
Here you go. This guy put a MII in an early A.
Mustang II Front End
I will check it outHa! That's the one I installed!
Yep I looked that over. that’s not the one for me. I have given up on putting a hemi in. I think I’m gonna go back to my 408 plans. It’s a bolt in I can put my March serpentine system back on my air conditioning in the same place use my same lines I made. too much stuff I have to throw away or try to sell to do the switch.Ha! That's the one I installed!
